Installation location overview - engine 1.4 TSI compartment
Обзор мест установки - моторный отсек бензиновых двигателей 1,4 TSI
Skoda Karoq (NU7) c 2019 модельного года
Skoda Kodiaq (NS7) с 2017 года выпуска,
Skoda Kodiaq (NS7) с 2019 года выпуска,
Skoda Superb III (3V3, 3V5) с 2015 года выпуска.
Двигатели 1,4/92 kW и 1,4/110 kW TSI engine
Буквенное обозначение двигателей: CZCA, CZDA, CZEA
Также эти двигатели ставятся на: Skoda Octavia 3 (5E, NL) Superb 3 (3V), Yeti (5L, 67), Rapid (NH, NK), VW Tiguan 2 (AD1, BT1), Passat B8 (3G), Polo Sedan (614), Jetta 6 (AV3, 16), Sharan 2 (7N), Touran 2 (5T1), SEAT Leon 3 (5F), Audi A3 (8V), A1 (8X), Q3 (8UG) и др.
Installation location overview - engine 1.4 TSI (CZCA, CZDA, CZEA) compartment
1 - Camshaft control valve 1 N205 with integrated oil strainer
2 - Camshaft adjustment valve 1 in the outlet N318
Only fitted for engine identification characters CZDA, CZEA with integrated oil strainer
3 - Lambda probe 1 in front of the catalytic converter GX10 comprises:
Lambda probe G39
Lambda probe heater Z19
4 - Lambda probe 1 after catalytic converter GX7 comprises:
Lambda probe downstream of catalytic converter G130
Lambda probe heater 1 downstream of catalytic converter Z29
5 - Charge pressure regulator V465
6 - Exhaust cam adjuster for cylinder 2 N587
Only fitted for engine identification characters CZEA
7 - Exhaust cam adjuster for cylinder 3 N595
8 - Inlet cam adjuster for cylinder 2 N583
9 - Inlet cam adjuster for cylinder 3 N591
10 - Hall sender 3 G300
11 - Hall sender G40
12 - Engine control unit J623
13 - Coolant temperature sender at radiator outlet G83
14 - Throttle valve control unit GX3 comprises:
Throttle valve control unit J338
Throttle valve drive G186
Throttle valve drive angle sender 1 G187
Throttle valve drive angle sender 2 G188
15 - Charge pressure sender GX26 comprises:
Charge pressure sender G31
Intake air temperature sender G42
16 - Intake manifold pressure sender GX9 comprises:
Intake air temperature sender 2 G299
Intake manifold pressure sender G71
17 - Charge air cooler pump V188
18 - Ignition coils with a power output stage
Ignition coil 1 with power output stage N70
Ignition coil 2 with power output stage N127
Ignition coil 3 with power output stage N291
Ignition coil 4 with power output stage N292
When installing new spark plugs, grease the ignition coils with power output stage with lubricating paste G 052 565 A1.
Installation overview - engine 1.4 TSI (CZCA, CZDA, CZEA) from front
1 - Knock sensor 1 G61
2 - Oil pressure switch for reduced oil pressure F378
3 - Fuel pressure sender G247
4 - Activated charcoal filter solenoid valve 1 N80
5 - Injection valves
Injection valve for cylinder 1 N30
Injection valve for cylinder 2 N31
Injection valve for cylinder 3 N32
Injection valve for cylinder 4 N33
6 - Control valve for fuel pressure N276
on the high pressure pump
7 - Engine speed sender G28
Installation overview - engine 1.4 TSI (CZCA, CZDA, CZEA) from rear
1 - Oil level and oil temperature sender G266
2 - Coolant temperature sender G62
3 - Oil pressure switch F1
4 - Oil pressure control valve N428
Lambda probe G39
1 - клапан распределительного вала 1 N205 со встроенным масляным фильтром
2 - клапан регулировки распредвала 1 на выходе N318
Подходит только для обозначения двигателя CZDA, CZEA со встроенным масляным фильтром
3 - Лямбда-зонд 1 перед каталитическим нейтрализатором GX10 содержит:
Лямбда-зонд G39
Лямбда-зонд с подогревом Z19
4 - Лямбда-зонд 1 после каталитического нейтрализатора GX7 содержит:
Лямбда-зонд после каталитического нейтрализатора G130
Нагреватель лямбда-зонда 1 после каталитического нейтрализатора Z29
5 - регулятор давления наддува V465
6 - Регулятор выпускных кулачков для цилиндра 2 N587
Подходит только для двигателя CZEA
7 - Регулятор выпускных кулачков для цилиндра 3 N595
8 - Регулятор впускных кулачков для цилиндра 2 N583
9 - Регулятор впускных кулачков для цилиндра 3 N591
10 - Датчик Холла 3 G300
Подходит только для идентификационных знаков двигателя CZDA, CZEA
11 - Датчик Холла G40
12 - Блок управления двигателем J623
13 - Датчик температуры охлаждающей жидкости на выходе из радиатора G83
14 - Блок управления дроссельной заслонкой GX3 содержит:
Блок управления дроссельной заслонкой J338
Привод дроссельной заслонки G186
Датчик угла поворота дроссельной заслонки 1 G187
Датчик угла поворота дроссельной заслонки 2 G188
15 - Датчик давления наддува GX26 содержит:
Датчик давления наддува G31
Датчик температуры воздуха на впуске G42
16 - Датчик давления во впускном коллекторе GX9 содержит:
Датчик температуры воздуха на впуске 2 G299
Датчик давления во впускном коллекторе G71
17 - Насос охладителя наддувочного воздуха V188
18 - Катушки зажигания с выходным каскадом мощности
Катушка зажигания 1 с выходной каскадом мощности N70
Катушка зажигания 2 с выходным каскадом мощности N127
Катушка зажигания 3 с выходным каскадом мощности N291
Катушка зажигания 4 с выходным каскадом мощности N292
При установке новых свечей зажигания смазывайте катушки зажигания ступенью выходной мощности смазочной пастой G 052 565 A1.
1 - Датчик детонации 1 G61
2 - Датчик давления масла для снижения давления масла F378
3 - Датчик давления топлива G247
4 - Электромагнитный клапан фильтра с активированным углем 1 N80
5 - впрыскивающие клапаны
Клапан впрыска для цилиндра 1 N30
Клапан впрыска для цилиндра 2 N31
Клапан впрыска для цилиндра 3 N32
Клапан впрыска для цилиндра 4 N33
6 - Регулирующий клапан давления топлива N276
на насосе высокого давления
7 - Датчик оборотов двигателя G28
1 - Датчик уровня масла и температуры масла G266
2 - Датчик температуры охлаждающей жидкости G62
3 - Датчик давления масла F1
4 - клапан контроля давления масла N428
