Руководство Замена масла в муфте Haldex (полный привод)
Changing the oil in the four-wheel drive clutch (Haldex / BorgWarner) Skoda Karoq
Special tools and workshop equipment required
Filling device VAS 6291 or VAS 6291/A
Catch pan VAS 6208
Oil for four-wheel drive clutch
Precondition
• Vehicle on level ground
Drain oil
– Raise vehicle.
– Remove the noise insulation
– Unscrew heat shield for right drive shaft (if present) from angle gearbox.
– Place a catch pan under the four-wheel drive clutch.
– Unscrew drain plug (2) and drain all oil from the four-wheel drive clutch.
– Screw new drain plug (2) and tighten to tightening torque
Replenish oil
– Unscrew oil filler plug (1).
– Screw in the adapter of the filling device VAS 6291/3 into the filler hole up to the stop.
– Connect and secure the angled piece of the filling device to the adapter VAS 6291/3.
– Route hose of filling device above drive shaft and pull out of the vehicle.
• The hose must not sag.
– Lower the vehicle.
– Ensure that the valve -arrow- is closed.
– Screw oil reservoir (A) onto the filling device .
– Open valve (arrow) and hold oil reservoir as shown in the figure.
Then fill the four-wheel drive clutch with oil.
Note
If the angle gearbox is correctly filled, oil flows out at the adapter VAS 6291/3.
If no oil flows out, continue the filling procedure.
– Place oil reservoir under the four-wheel drive clutch (e.g. trolley) so that the excess oil flows back into the oil reservoir.
– If no more oil flows back, remove filling device .
– Once it is filled correctly, unscrew the adapter VAS 6291/3.
– Screw in the »old« oil filler plug and tighten.
– Start engine, engage a gear and allow gearbox to rotate for about 2 minutes.
– Switch off engine and unscrew oil drain plug.
– Check oil level, if necessary top up gear oil again to lower edge of filler hole.
• The four-wheel drive clutch must be filled up to the bottom edge of the oil filler hole.
– Screw in new oil filler plug.
– Raise vehicle.
– Screw in oil filler plug (A) and tighten to tightening torque.
– Raise vehicle.
– Install heat shield for right drive shaft (if present).
– Install the noise insulation.
Tightening torqueNm
Filler screw for high-performance oil for four-wheel drive clutch
• Replace bolt.
15 Nm
Drain plug for high-performance oil for four-wheel drive clutch
• Replace bolt.
38 Nm
По пробкам - номера не подскажите ?
Насос чистый,без соплей,масло серенькое,прокачать Васей не удалось нет пункта насос,проехал квартал по кругу опять на подъёмник проверили уровень немножко вытекло,ошибок никаких,у меня фишка вынимается на насосе,с мозгов не выдёргивали.
    86.4 КБ · Просмотры: 296
Оказывается на машинах 21 модельного года начали ставить муфты 6 поколения,и мозги в самом насосе где втыкается фишка.
А я то думаю ? почему у меня фишка прямо на насосе. Залил ravenol awd-h.
Второй раз менял масло в муфте на 60 к. Как и в первый раз заливал FEBI.
Оба раз делал со снятием и чисткой насоса. Как не странно, при первой замене фильтр насоса был значительно грязнее
а подскажите, на 22 модельного года какая муфта и какое масло надо в нее?
