Руководство Замена масла в муфте Haldex (полный привод)
Changing the oil in the four-wheel drive clutch (Haldex / BorgWarner) Skoda Karoq
Special tools and workshop equipment required
Filling device VAS 6291 or VAS 6291/A
Catch pan VAS 6208
Oil for four-wheel drive clutch
Precondition
• Vehicle on level ground
Drain oil
– Raise vehicle.
– Remove the noise insulation
– Unscrew heat shield for right drive shaft (if present) from angle gearbox.
– Place a catch pan under the four-wheel drive clutch.
– Unscrew drain plug (2) and drain all oil from the four-wheel drive clutch.
– Screw new drain plug (2) and tighten to tightening torque
Replenish oil
– Unscrew oil filler plug (1).
– Screw in the adapter of the filling device VAS 6291/3 into the filler hole up to the stop.
– Connect and secure the angled piece of the filling device to the adapter VAS 6291/3.
– Route hose of filling device above drive shaft and pull out of the vehicle.
• The hose must not sag.
– Lower the vehicle.
– Ensure that the valve -arrow- is closed.
– Screw oil reservoir (A) onto the filling device .
– Open valve (arrow) and hold oil reservoir as shown in the figure.
Then fill the four-wheel drive clutch with oil.
Note
If the angle gearbox is correctly filled, oil flows out at the adapter VAS 6291/3.
If no oil flows out, continue the filling procedure.
– Place oil reservoir under the four-wheel drive clutch (e.g. trolley) so that the excess oil flows back into the oil reservoir.
– If no more oil flows back, remove filling device .
– Once it is filled correctly, unscrew the adapter VAS 6291/3.
– Screw in the »old« oil filler plug and tighten.
– Start engine, engage a gear and allow gearbox to rotate for about 2 minutes.
– Switch off engine and unscrew oil drain plug.
– Check oil level, if necessary top up gear oil again to lower edge of filler hole.
• The four-wheel drive clutch must be filled up to the bottom edge of the oil filler hole.
– Screw in new oil filler plug.
– Raise vehicle.
– Screw in oil filler plug (A) and tighten to tightening torque.
– Raise vehicle.
– Install heat shield for right drive shaft (if present).
– Install the noise insulation.
Tightening torqueNm
Filler screw for high-performance oil for four-wheel drive clutch
• Replace bolt.
15 Nm
Drain plug for high-performance oil for four-wheel drive clutch
• Replace bolt.
38 Nm
Вместо VAS 6291 or VAS 6291/A можно использовать шприц жане (цена от 70 руб.) и трубочку на него, желательно прозрачную.
Замена масла в муфте полного привода Шкода Карок
Приспособление для заправки муфты полного привода - VAS 6291-
Поддон
Специальное масло для муфт полного привода см. Электронный каталог запчастей
Слив масла
– Поднять автомобиль.
– Подставить поддон под муфту полного привода.
– Выкрутить резьбовую пробку сливного отверстия -стрелка- и полностью слить масло муфты полного привода.
– Вкрутить и затянуть новую сливную пробку с прокладкой -стрелка-
Заливка масла
– Отвернуть пробку маслозаливного отверстия -A-.
– Вкрутить переходник -A-приспособления для заправки -VAS 6291- до упора в отверстие для заливки масла.
– Подсоединить и закрепить угловой соединитель -B- к адаптеру -A-.
– Пропустить шланг приспособления для заправки поверх приводного вала и вытянуть из автомобиля.
Шланг не должен провисать. Он должен выходить над левым задним колесом.
– Опустить автомобиль.
Следить, чтобы клапан -стрелкаприспособления для заправки -VAS 6291- был закрыт перед прикручиванием ёмкости.
– Накрутить бачок для масла -A- на приспособление для заправки -VAS 6291-.
– Открыть кран -стрелка- и удерживать ёмкость, как показано на рисунке.
Муфта полного привода заполняется маслом.
Когда муфта полного привода наполнится, уровень масла находится выше адаптера -A-.
– Поставить ёмкость с маслом ниже уровня муфты полного привода, чтобы излишки масла стекли обратно в ёмкость.
Тем самым обеспечивается правильный уровень масла в муфте полного привода – до края маслозаливного отверстия.
– Если масло больше не вытекает, снять устройство для заливки масла -VAS 6291-.
– Проверить уровень масла в муфте полного привода см. Проверка уровня масла
Если уровень масла находится в пределах нормы:
– Вкрутить новую резьбовую пробку -A- в отверстие для заправки масла и затянуть
Пробка маслозаливного отверстия
для специального масла для муфт
полного привода
Заменить винт.
15 Н·м
Резьбовая пробка сливного
отверстия для специального
масла для муфт полного привода
Заменить винт.
38 Н·м
- Измерение температуры масла
- Температура масла должна быть в пределах от 20 до 40 °C.
- Автомобиль должен стоять горизонтально.
- Главная передача в монтажном положении.
При необходимости совершить поездку для прогрева масла.
– Подставить под заднюю главную передачу поддон.
– Вывернуть пробку для проверки уровня масла -А-.
Уровень масла соответствует норме, если корпус муфты заполнен до маслозаливного отверстия
(минимальный допустимый уровень — 3 мм ниже края маслозаливного отверстия).
Долить масло в муфту полного привода
– Ввернуть новую пробку -А- с новым уплотнительным кольцом и затянуть её
полного привода
Заменить винт.
15 Н·м
На 30 тыс. км поменял масло в Халдекс - масло металлического цвета, сетка насоса вся в слизи и грязи. Пробки-болты менял, болты насоса и резинки оставил старые.
Всем причастным настоятельно рекомендую данную процедуру.
А с чем такое состояние масла может быть связано? Возможно ли что с завода льют не самое хорошее масло?
Менял в Тигуане 2 на третьем ТО масло в Халдекс, пробег был около 22 тыс.
Сливалось довольно чистое.
Больше всего напрягло когда дилерский мастер, после слива масла, начал туда пшикать каким-то очистителем из баллона внутрь муфты.
Оно конечно потом стекло... но осадочек остался... у меня на душе как минимум :)))
В руководствах такого не встречал... :mda:
Это у них в крови попшикать в открытый агрегат. Я недавно менял масло на своём айсине, мне меняли несколькими частичными заменами подряд, аппаратом не получилось, так рядом на подъемнике висел ниссан. Ему сняли с коробки поддон и прямо в коробку (в видимую нижнюю часть) этим очистителем начали всё заливать. Он правда быстро испарялся, но тоже как-то странно показалось. Ладно ещё поддон изнутри, но коробку.....
Очевидно с принципом работы Haldex. Фрикционы трутся, получается пыль, которую смывает масло.
Такая же история и в ДСГ, только в других масштабах, в 45 тыр буду там масло менять.
А чего такого то? Грязи меньше будет. Всё это хорошо очистителем тормозов в баллоне делать, струя далеко добивает
дилер сказал что нужно менять сливную и заливную пробки. а так же почистить что то там внутри. и нужен комплект прокладок под насос этой муфты...
есть информация?
@Toljen, дилер желает снять насос и поменять там покладки?
Можете согласиться, но скажите что это все только за его счет. ;)
В мануале написано четко: меняются только пробки, сливная и заливная.
Парни подскажите какое все таки масло в халдекс лить? G060175A2 или все таки G065175A2 ? Авто Карок 4х4 2020 год. вин дам если нужно. на форумах 065, манагер автодока клянется что 060 и никакое больше.... дилер вообще молчит.
Нужно масло G065 скорее всего - муфта в кароке стоит новая с блоком управления встроенным в электромотор. Что будет если залить g060 неизвестно, возможно что и ничего, но я слышал, что лучше не экспериментировать (есть аналоги febi или motul).
Интересно по вину глянуть, пишите вин.
G65. Халдекс 6 стоит.
Совершенно верно!
Я менял уже на 25 тысячах - сетка средней загрязнённости в соплях, эксплуатация почти один город. Снимал сетку, потом чёрт дёрнул лезть дальше у меня высыпались какие то пружинки толкатели я думаю про себя "так без паники"))) почистил всё собрал всё работает!
Вспоминается мне халдекс 4 на йетьке - там фильтр стоял и не было никакой сетки на двигателе и масло выливалось хорошее, жаль фильтр убрали...
