Sound system Skoda Karoq
Overview of locations where sound system is fitted
1 - Front treble speaker
2 - Central speaker
3 - Rear treble speaker
4 - Subwoofer
5 - Rear bass speaker
6 - Digital sound package control unit - J525
7 - Front bass speaker
Removing and installing digital sound package control unit/amplifier
Removing
– Switch off all electrical components and take out the ignition key.
– Push the left front seat completely towards the rear and the highest point.
– Remove expanding rivets (2) and remove cover (1) towards the front.
– Remove screws (2).
– Gently swivel out the control unit (1) and pull it out of the holder (3).
– Slacken by tilting out the clamp and disconnect the plug connection.
– Release and disconnect the “MOST bus” databus (2).
– Protect socket for MOST-Bus Databus (2) with cover (1). You can also use another suitable way (e.g. wrap around a clean film and tape up).
Installing
Installation is performed in the reverse order, pay attention to the following points:
– When replacing, code the new control unit with the Vehicle diagnostic tester.
– If the MOST-Bus data bus is damaged, replace databus with end pieces
Specified torques
Removing and installing the rear treble speaker -R14- / -R16-
Removing
– Remove rear door trim
Carefully drill out the heads of the plastic rivets (1) with a suitable drill and remove the speaker (2).
– Remove remains of the plastic rivets (cut off, grind down).
Installing
– Secure new speaker (2) with screws (3)
Specified torques
Remove and install front tweeters - R20- / -R22-
Front tweeter is integrated into the A-pillar trim at the top. Replace the AS column cover if damaged
Removing and installing the rear bass loudspeaker -R15- / -R17-
Removing
– Switch off the ignition and all electrical components.
– Remove the door trim panel from which you are removing the speaker
– Disconnect socket connector at the loudspeaker.
– Drill out the rivets (1) with a suitable drill and remove the speaker (2).
Caution
- It is important to remove all the drill swarf from the door since it can otherwise lead to corrosion.
- Any damage to the paintwork which is caused by drilling out the rivets must be repaired immediately by a specialist.
Installing
Installation is carried out in the reverse order.
Removing and installing the front woofers -R21- / -R23-
Removing
Caution
Installing
Removing and installing subwoofer - R211-
The subwoofer - R211 is located in the recess for the spare wheel.
Removing
– Raise and lock luggage compartment floor
– Unlock the plug connection (2) and disconnect.
– Unscrew securing nut (3) and remove subwoofer (1).
Installing
Specified torques
Removing and installing the central speaker
Special tools and workshop equipment required
Disassembly wedge - 3409-
Only on vehicles with the equipment “Soundsystem”
Removing
Caution
When using the lever tool, mask points where the lever tool is applied using commercially available adhesive tape.
– Unclip cover (1) with the disassembly wedge and remove from the dash panel (arrows).
– Unscrew screws (1) and remove speaker (2).
– Disconnect plug.
Installing
Specified torques
2 - Central speaker
4 - Subwoofer
Removing
Installing
Specified torques
Component | Nm |
Screw of the control unit | 1.5 Nm |
Removing
Installing
Specified torques
Component | Nm |
Fixing screws for speakers | 0.5 Nm |
Removing
Caution
Installing
Removing
Caution
Installing
Removing
Installing
Specified torques
Component | Nm |
Screw of the subwoofer | 3 Nm |
Nut of the subwoofer | 3 Nm |
Removing
Caution
– Disconnect plug.
Installing
Specified torques
Component | Nm |
Screws of the speaker | 1 Nm |
