Полный скан диагностики Skoda Karoq
Kasach
Германия
Skoda Karoq Style 2,0 TDI
Вроде, получилось с софтом на английском
Полный лог Skoda Karoq 2,0 TDI
Data version: 20190930 DS308.0
Ross-Tech.com
VIN: TMBJJ7NU0L... License Plate:
Mileage: 457km-283mi Repair Order:
Chassis Type: NU-SK37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 17 19 20 2B 42 44 4B 52 5F 6D BB BC
D6 D7
VIN: TMBJJ7NU0L.... Mileage: 457km-283miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DFFA) Labels: None
Part No SW: 04L 906 027 AB HW: 04L 907 309 P
Component: R4 2.0l TDI H26 9600
Revision: B4H26---
Coding: 0119001204441D093000
Shop #: WSC 31000 790 00225
ASAM Dataset: EV_ECM20TDI01104L906027AB 004003
ROD: EV_ECM20TDI01104L906027AB_AU37.rod
VCID: 6B823D1F93094A2F0C5-803E
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 ER HW: 5Q0 614 517 BN
Component: ESC H35 0190
Revision: 00000000 Serial number: 62819000000458
Coding: 1F076AA130210C75477D060962C725F8560C30E26046A4733463F078D0024A0B00000C6212120B095A35351919323200
Shop #: WSC 31000 790 00268
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 05566BA795AD9C5FFA1-8050
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0529784195
Coding: 032C0C0623
ASAM Dataset: EV_KessyHellaMQBAB 004052
ROD: EV_KessyHellaMQBAB_VW48.rod
VCID: 45D6ABA7D52D5C5FBA1-8010
Sensor Controlled Power Rear Lid:
Subsystem 1 - Part No SW: 3G0 962 243 B HW: 3G0 962 243 B
Component: GEB.F.Heckoef H17 0904
Serial number: 58661304
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 565 907 044 CL HW: 565 907 044 CL
Component: Climatronic H04 2202
Revision: 00001K00
Coding: 06010104002114011005000800101022
ASAM Dataset: EV_ACClimaBHBVW37X 006150
ROD: EV_ACClimaBHBVW37X_006.rod
VCID: 678A412F8FE16E4F68D-8032
Fresh Air Blower Front:
Geber für Kältemitteldruck/Kältemitteltemperatur:
Air quality sensor:
Subsystem 3 - Part No SW: 5Q0 907 659 C HW: 5Q0 907 659 C
Component: G238 _AQS H30 0119
Serial number: 94220468
1 Fault Found:
1048835 - Functionality limited due to Engine Control Module
P1719 00 [008] - -
[PTC-Reduzierung durch MSG]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 57
Mileage: 440 km
Date: 2019.12.28
Time: 10:07:59
Voltage terminal 30: 14.3 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Auxiliary heater: in stages-Act.val.: 2
Auxiliary heater: in stages-Specified value: 3
Auxiliary heater: in stages-Specified value for control: 3
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 DH HW: 5Q0 937 084 CG
Component: BCM MQBAB H H40 0312
Serial number: 01001925802311
Coding: 000000000000000000000000000000000000000000000000000000000000
Shop #: WSC 31000 790 00232
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW27.rod
VCID: 015E7FB78185B07FC69-8054
Rain Light Recognition Sensor:
Subsystem 1 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 23738857X81A955555A0
Coding: 80006E
Sensor For Anti Theft Alarm System:
Subsystem 2 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY191750KN2
Alarm horn:
Subsystem 3 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000644178
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 AG HW: 5Q1 953 569 A
Component: Lenks.Modul H13 0170
Serial number: 0100300920190C301791
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058319283
Coding: 0471151841
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000_009_VW37.rod
VCID: 50F88AF31A6F89F7197-8004
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 2A04608158FF8728749C814510408700000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
VCID: 43D2B5BFDB19626F945-8016
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PLQHZ6+
Coding: 98CCC0C0000000005C5400CF000800000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0B425D9FB3C9EA2FAC5-805E
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 454 001 809 19
Component: SideSensor_Df 008 0887
Serial number: 357000000004EC19FF32
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 454 002 109 19
Component: SideSensor_Pf 008 0887
Serial number: 35800000000CD634F04U
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 454 800 910 19
Component: SideSensor_Dr 301 0148
Serial number: 35100FBE6D119000000-
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 454 800 710 19
Component: SideSensor_Pr 301 0148
Serial number: 35200CF98D119000000Z
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 454 802 409 19
Component: FrontSensor_D 304 0149
Serial number: 3550091B5D219000000L
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 565 920 790 C HW: 565 920 790 C
Component: KOMBI 503 4193
Coding: 04A40C162F800008018C72011001000080000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_VW37.rod
VCID: 1E6424CB103B6F87DBB-804A
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000181707
Coding: 0B0100045F087300A91002DA080F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF.rod
VCID: 70B82A73BA2FA9F7397-8024
Alternator:
Component: 4-00-03-00-04
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 3V0 919 719 E HW: 3V0 919 719 E
Component: E221__MFL-PR6 H03 0180
Serial number: 000000000D0091141019
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 75886003001910100FD6
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 H HW: 5Q0 907 155 H
Component: U13DCAC H27 0810
Serial number: 5082849
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 57A 857 511 HW: 3G0 857 511 G
Component: FLA H10 0010
Revision: AA001001
Coding: 040400F100000000000000
ASAM Dataset: EV_HighBeamAssisAU33X 001019
ROD: EV_HighBeamAssisAU33X_VW37.rod
VCID: 6888421382FF6137617-803C
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 19000279460002
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_AU37.rod
VCID: 3332E57F8BB9D2EF045-8066
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000392645145
Coding: 00150820D000020000001100
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCID: 4DC693870D5DA41F721-8018
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 407 A HW: 5Q0 959 163
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000034751277
Coding: 010200
Address 44: Steering Assist (J500) Labels:| 5Q0-910-143.clb
Part No SW: 5Q0 910 143 C HW: 5Q0 910 143
Component: MQB_VWBS_GEN2 212 2211
Serial number: 958026 00
Coding: 0100001000400110
ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
VCID: 2B02FD1F53898A2F4C5-807E
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 15101910800030
Coding: 000000070900056200003D01190000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 003003
ROD: EV_MultiModulContiVW48X_003.rod
VCID: 372AD16F9FC13ECF38D-8062
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000392803126
Coding: 00150020D000020000001F00
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
VCID: 4CC09E83F647AD1765F-8018
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 408 A HW: 5Q0 959 164
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000034727357
Coding: 190200
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 565 035 864 HW: 565 035 864
Component: MU-S-N-ER H41 0478
Serial number: SKZAZ2W1074199
Coding: 03230601FF0000000111000100000A002F0208F401200400CF
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW41.rod
VCID: 5AEC68DB4C93C3A7E73-800E
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 565 919 605 B HW: 565 919 605 B
Component: ABT_Std-2_Nav H53 8130
Serial number: SKZ6ZHW2920244
Data medium:
Subsystem 2 - Part No SW: 5L0 051 236 BA HW: -----------
Component: ECE AS 19/20 --- 1115
Serial number: --------------------
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 S HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0271
Revision: -------- Serial number: A2-C737-6291-8
Coding: 1808
ASAM Dataset: EV_DeckLidCONTIAU736 001017
ROD: EV_DeckLidCONTIAU736_VW37.rod
VCID: 48C8A293E23F4137417-801C
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AJ HW: 7P5 941 591 A
Component: LED1L H07 0011
ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: 045076A39E97A557EDF-8050
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0011
ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End
----------(Elapsed Time: 01:35, VBatt start/end: 12.3V/12.3V)-----------
Donnerstag,26,Dezember,2019,10:51:41:52135
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 7 x64
VCDS Version: MFT 19.6.2.1 HEX-V2 CB: 0.4508.4
Datenstand: Diagnosetool.de
Fahrzeug-Ident.-Nr.: KFZ-Kennzeichen:
Kilometerstand: 436km Reparaturauftrag:
Fahrzeugtyp: NU-SK37 (3Q0)
D6 D7
Fahrzeug-Ident.-Nr.: Kilometerstand: 436km
01-Motorelektronik -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
20-Fernlichtassistent -- Status: i.O. 0000
2B-Lenksäulenverrieg. -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
4B-Multifunktionsstg. -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
5F-Informationselek. I -- Status: Fehler 0010
6D-Heckklappe -- Status: i.O. 0000
BB-Türelektronik hinten links -- Status: i.O. 0000
BC-Türelektronik hinten rechts -- Status: i.O. 0000
D6-Lichtsteuerung links 2 -- Status: i.O. 0000
D7-Lichtsteuerung rechts 2 -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-DFFA) Labeldatei: Keine
Teilenummer SW: 04L 906 027 AB HW: 04L 907 309 P
Bauteil: R4 2.0l TDI H26 9600
Revision: B4H26---
Codierung: 0119001204441D093000
Betriebsnr.: WSC 31000 790 00225
ASAM Datensatz: EV_ECM20TDI01104L906027AB 004003
VCID: 6B823D1F93094A2F0C4-803E
Kein(e) Fehlercode(s) gefunden.
Adresse 03: Bremsenelektronik (J104) Labeldatei: Keine
Teilenummer SW: 5Q0 614 517 ER HW: 5Q0 614 517 BN
Bauteil: ESC H35 0190
Revision: 00000000 Seriennummer: 62819000000458
Codierung: 1F076AA130210C75477D060962C725F8560C30E26046A4733463F078D0024A0B00000C6212120B095A35351919323200
Betriebsnr.: WSC 31000 790 00268
ASAM Datensatz: EV_Brake1UDSContiMK100IPB 038007
VCID: 05566BA795AD9C5FFA0-8050
Adresse 05: Zugangs-/Startber. (J518) Labeldatei:| DRV\5Q0-959-435.clb
Teilenummer SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Bauteil: VWKESSYMQB 037 1307
Revision: 00037000 Seriennummer: 0529784195
Codierung: 032C0C0623
ASAM Datensatz: EV_KessyHellaMQBAB 004052
VCID: 45D6ABA7D52D5C5FBA0-8010
Steuergerät für Heckklappenöffnung:
Subsystem 1 - Teilenummer SW: 3G0 962 243 B HW: 3G0 962 243 B
Bauteil: GEB.F.Heckoef H17 0904
Seriennummer: 58661304
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei:| DRV\5G0-907-044.clb
Teilenummer SW: 565 907 044 CL HW: 565 907 044 CL
Bauteil: Climatronic H04 2202
Revision: 00001K00
Codierung: 06010104002114011005000800101022
ASAM Datensatz: EV_ACClimaBHBVW37X 006150
VCID: 678A412F8FE16E4F68C-8032
Steuergerät für Frischluftgebläse (vorn):
Sensor für Luftgüte:
Subsystem 3 - Teilenummer SW: 5Q0 907 659 C HW: 5Q0 907 659 C
Bauteil: G238 _AQS H30 0119
Seriennummer: 94220468
Adresse 09: Zentralelektrik (J519) Labeldatei: Keine
Teilenummer SW: 5Q0 937 084 DH HW: 5Q0 937 084 CG
Bauteil: BCM MQBAB H H40 0312
Seriennummer: 01001925802311
Codierung: 000000000000000000000000000000000000000000000000000000000000
Betriebsnr.: WSC 31000 790 00232
ASAM Datensatz: EV_BCMMQB 020001
VCID: 015E7FB78185B07FC68-8054
Sensor für Regen- und Lichterkennung:
Subsystem 1 - Teilenummer SW: 81A 955 555 A HW: 81A 955 555
Bauteil: G397_RLFSS H06 0002
Seriennummer: 23738857X81A955555A0
Codierung: 80006E
Sensor für Diebstahlwarnanlage:
Subsystem 2 - Teilenummer SW: 5Q0 951 172 HW: 5Q0 951 172
Bauteil: Sensor, DWA 005 0316
Seriennummer: 000000000ZY191750KN2
Alarmhorn:
Subsystem 3 - Teilenummer SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Bauteil: Sirene, DWA 004 0007
Seriennummer: 00000000000000644178
Lenkstockschalter:
Subsystem 4 - Teilenummer SW: 5Q1 953 521 AG HW: 5Q1 953 569 A
Bauteil: Lenks.Modul H13 0170
Seriennummer: 0100300920190C301791
Adresse 10: Einparkhilfe 2 (J446) Labeldatei:| DRV\5Q0-919-294.clb
Teilenummer SW: 5QA 919 294 G HW: 5QA 919 294
Bauteil: PDC 8 Kanal H08 0061
Seriennummer: 000150058319283
Codierung: 0471151841
ASAM Datensatz: EV_EPHVA18AU3700000 009046
VCID: 50F88AF31A6F89F7196-8004
Adresse 13: Distanzregelung (J428) Labeldatei:| 2Q0-907-572.clb
Teilenummer SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Bauteil: ACCCONTIMQB H03 0372
Codierung: 2A04608158FF8728749C814510408700000000000000000004
ASAM Datensatz: EV_ACCMRRCONTIVW376 003016
VCID: 43D2B5BFDB19626F944-8016
Adresse 15: Airbag (J234) Labeldatei:| DRV\5Q0-959-655.clb
Teilenummer SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Bauteil: Airbag VW21 006 0720
Revision: -------- Seriennummer: 003Z2PLQHZ6+
Codierung: 98CCC0C0000000005C5400CF000800000065
ASAM Datensatz: EV_AirbaVW21TS6VW48X 001014
VCID: 0B425D9FB3C9EA2FAC4-805E
Crashsensor für Seitenairbag Fahrerseite:
Subsystem 1 - Teilenummer SW: ----------- HW: 454 001 809 19
Bauteil: SideSensor_Df 008 0887
Seriennummer: 357000000004EC19FF32
Codierung: 2D2D2D
Crashsensor für Seitenairbag Beifahrerseite:
Subsystem 2 - Teilenummer SW: ----------- HW: 454 002 109 19
Bauteil: SideSensor_Pf 008 0887
Seriennummer: 35800000000CD634F04U
Codierung: 2D2D2D
Crashsensor für Seitenairbag hinten Fahrerseite:
Subsystem 3 - Teilenummer SW: ----------- HW: 454 800 910 19
Bauteil: SideSensor_Dr 301 0148
Seriennummer: 35100FBE6D119000000-
Codierung: 2D2D2D
Crashsensor für Seitenairbag hinten Beifahrerseite:
Subsystem 4 - Teilenummer SW: ----------- HW: 454 800 710 19
Bauteil: SideSensor_Pr 301 0148
Seriennummer: 35200CF98D119000000Z
Codierung: 2D2D2D
Crashsensor für Frontairbag Fahrerseite:
Subsystem 5 - Teilenummer SW: ----------- HW: 454 802 409 19
Bauteil: FrontSensor_D 304 0149
Seriennummer: 3550091B5D219000000L
Codierung: 2D2D2D
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5G0-920-XXX-17.clb-SRI3
Teilenummer SW: 565 920 790 C HW: 565 920 790 C
Bauteil: KOMBI 503 4193
Codierung: 04A40C162F800008018C62011001000080000000
ASAM Datensatz: EV_DashBoardVDDMQBA0 001042
VCID: 1E6424CB103B6F87DBA-804A
Adresse 19: Diagnoseinterface (J533) Labeldatei:| DRV\3Q0-907-530-V1.clb
Teilenummer SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Bauteil: GW MQB High 442 4388
Revision: -------- Seriennummer: 0000181707
Codierung: 0B0100045F087300A91002DA080F00010001070000000000000000000000
ASAM Datensatz: EV_GatewNF 013026
ROD: EV_GatewNF.rod
VCID: 70B82A73BA2FA9F7396-8024
Generator:
Bauteil: 4-00-03-00-04
Steuergerät für Multifunktionslenkrad:
Subsystem 2 - Teilenummer SW: 3V0 919 719 E HW: 3V0 919 719 E
Bauteil: E221__MFL-PR6 H03 0180
Seriennummer: 000000000D0091141019
Steuergerät für Batterieüberwachung:
Subsystem 3 - Teilenummer SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Bauteil: J367-BDMConti H03 1051
Seriennummer: 75886003001910100FD6
Wechselrichter für Netzsteckdose:
Subsystem 4 - Teilenummer SW: 5Q0 907 155 H HW: 5Q0 907 155 H
Bauteil: U13DCAC H27 0810
Seriennummer: 5082849
Adresse 20: Fernlichtassistent (J844) Labeldatei:| DRV\8S0-857-511.clb
Teilenummer SW: 57A 857 511 HW: 3G0 857 511 G
Bauteil: FLA H10 0010
Revision: AA001001
Codierung: 040400F100000000000000
ASAM Datensatz: EV_HighBeamAssisAU33X 001019
VCID: 6888421382FF6137616-803C
Adresse 2B: Lenksäulenverrieg. (J764) Labeldatei:* DRV\5Q0-905-861.clb
Teilenummer SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Bauteil: ELV-MQBB H05 0020
Seriennummer: 19000279460002
ASAM Datensatz: EV_ELVMarqMQBA0 002002
VCID: 3332E57F8BB9D2EF044-8066
Adresse 42: Türelektr. Fahrer (J386) Labeldatei:* Umleit. fehlgeschl.!
Teilenummer SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Bauteil: TSG FS 007 0485
Seriennummer: 0000392645145
Codierung: 00150820D000020000001100
ASAM Datensatz: EV_DCU2DriveSideMAXHCONT 001005
VCID: 4DC693870D5DA41F720-8018
Türsteuergerät Fahrerseite hinten:
Subsystem 1 - Teilenummer SW: 5Q0 959 407 A HW: 5Q0 959 163
Bauteil: FOND_FHSG_DRV 007 0010
Seriennummer: 00000000000034751277
Codierung: 010200
Adresse 44: Lenkhilfe (J500) Labeldatei:| 5Q0-910-143.clb
Teilenummer SW: 5Q0 910 143 C HW: 5Q0 910 143
Bauteil: MQB_VWBS_GEN2 212 2211
Seriennummer: 958026 00
Codierung: 0100001000400110
ASAM Datensatz: EV_SteerAssisVWBSMQBGen2 002119
VCID: 2B02FD1F53898A2F4C4-807E
Adresse 4B: Multifunktionsstg. (J745) Labeldatei:| 3Q0-907-338-V2.clb
Teilenummer SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Bauteil: FCM MQB Low 003 0367
Seriennummer: 15101910800030
Codierung: 000000070900056200003D01190000000000000000000000000000000000
ASAM Datensatz: EV_MultiModulContiVW48X 003003
VCID: 372AD16F9FC13ECF38C-8062
Adresse 52: Türelektr. Beifahr. (J387) Labeldatei:* Umleit. fehlgeschl.!
Teilenummer SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Bauteil: TSG BFS 007 0485
Seriennummer: 0000392803126
Codierung: 00150020D000020000001100
ASAM Datensatz: EV_DCU2PasseSideMAXHCONT 001005
VCID: 4CC09E83F647AD1765E-8018
Türsteuergerät Beifahrerseite hinten:
Subsystem 1 - Teilenummer SW: 5Q0 959 408 A HW: 5Q0 959 164
Bauteil: FOND_FHSG_PSG 007 0010
Seriennummer: 00000000000034727357
Codierung: 190200
Adresse 5F: Informationselek. I (J794) Labeldatei:* Keine
Teilenummer SW: 565 035 864 HW: 565 035 864
Bauteil: MU-S-N-ER H41 0478
Seriennummer: SKZAZ2W1074199
Codierung: 03230601FF0000000111000100000A002F0208F401200400CF
ASAM Datensatz: EV_MUStd4CTSAT 001022
VCID: 5AEC68DB4C93C3A7E72-800E
Anzeige- und Bedienungseinheit 1 für Informationselektronik:
Subsystem 1 - Teilenummer SW: 565 919 605 B HW: 565 919 605 B
Bauteil: ABT_Std-2_Nav H53 8130
Seriennummer: SKZ6ZHW2920244
Datenträger:
Subsystem 2 - Teilenummer SW: 5L0 051 236 BA HW: -----------
Bauteil: ECE AS 19/20 --- 1115
Seriennummer: --------------------
2 Fehlercodes gefunden:
6720 - Rückfahrkamera
B1102 31 [008] - kein Signal
Sporadisch - bestätigt - geprüft seit letzter Löschung
Umgebungsbedingungen:
Fehlerstatus: 00000001
Fehlerpriorität: 3
Fehlerhäufigkeit: 1
Verlernzähler: 44
Kilometerstand: 44 km
Datum: 2019.12.14
Zeit: 15:42:16
Spannung Klemme 30: 12.6 V
6696 - Steuergerät für Schalttafeleinsatz am optischen Datenbus
U10C0 00 [008] - keine Kommunikation
[Control module for instrument cluster display: no communication]
Fehlerpriorität: 6
Fehlerhäufigkeit: 2
Verlernzähler: 41
Kilometerstand: 7 km
Datum: 2019.12.02
Zeit: 12:24:13
Spannung Klemme 30: 11.5 V
Adresse 6D: Heckklappe (J605) Labeldatei:| DRV\5Q0-959-107.clb
Teilenummer SW: 5Q0 959 107 S HW: 5Q0 959 107 J
Bauteil: HDSG-Modul H13 0271
Revision: -------- Seriennummer: A2-C737-6291-8
Codierung: 1808
ASAM Datensatz: EV_DeckLidCONTIAU736 001017
VCID: 48C8A293E23F4137416-801C
Adresse BB: Türelektronik hinten links
nicht erreichbar
Adresse BC: Türelektronik hinten rechts
nicht erreichbar
Adresse D6: Lichtsteuerung links 2 (A31) Labeldatei: 7P5-941-591.clb
Teilenummer SW: 7P5 941 591 AJ HW: 7P5 941 591 A
Bauteil: LED1L H07 0011
ASAM Datensatz: EV_LED_PLUS_L_KEBODAVW416 001003
VCID: 045076A39E97A557EDE-8050
Adresse D7: Lichtsteuerung rechts 2 (A27) Labeldatei: 7P5-941-591.clb
Bauteil: LED1R H07 0011
ASAM Datensatz: EV_LED_PLUS_R_KEBODAVW416 001003
Ende--(Dauer: 01:40, Batt.-Spannung Start/Ende: 11.8V/11.9V. VIgn 11.9V)---
Спасибо! :thankyou2::hat:
Версии установленных блоков, а также их заводские кодировки, частенько нужны бывают...
